McAfee security software and Windows 8.1
- Re: McAfee security software and Windows 8.1
17-11-2013 9:59 AM
I have tried setting this file properties to run in compatibility mode for both Windows 7 and then for Vista, but neither of these tests got rid of the compatibility Issues error message.
So, I then tried the second option in the error message, to "Run the program without getting help" and this seemed to go through to installing the software. But when it had all finished there wasn't a McAfee icon on my workspace nor a quick start icon present, so I rebooted and now there was a quick start icon but this was totally unresponsive to single click, double click and right click.
Are there known issues with windows 8 and the PlusNet security software? Or has anyone else manage to get it working under windows 8?
Cheers, Peter
17-11-2013 10:25 AM
http://www.plus.net/support/security/spam/plusnet_protect.shtml
Quote 3. Will it run on my computer?
Plusnet Protect works with Internet Explorer and Firefox on the following Operating Systems:
Windows XP (32 bit)
Windows Vista (32 and 64 bit)
Windows 7 (32 and 64 bit)
Your computer needs to have the following minimum specification:
256MB RAM
350MB of free hard drive space
300MHz processor
Note: Plusnet Protect doesn't currently work with Apple Macintosh computers.
17-11-2013 11:09 AM
17-11-2013 10:03 PM
18-11-2013 12:29 AM
18-11-2013 12:01 PM
30-12-2013 12:29 PM
I recently bought a new laptop and updated to Windows 8.1. The new laptop came with a McAfee trial installed.
I'm no stranger to McAfee and earlier this year started using Microsoft Security Essentials instead on my Vista laptop.
Now, a search of the Microsoft site shows that you cannot use Microsoft Security Essentials with Windows 8 and that instead I'll be using Windows Defender. Windows Defender is currently not active on my new laptop but I assume this is because McAfee is still running.
So, does anyone know if Windows Defender provides enough protection or should I opt for the likes of Avast or Avira?
Thanks in advance
Howard
30-12-2013 12:40 PM
Personally I wouldn't rely on either McAfee or Windows Defender http://www.av-comparatives.org/dynamic-tests/
I pay for mine but in the free ones Bitdefender is probably the best at present
30-12-2013 12:45 PM
30-12-2013 5:25 PM
I'm currently testing out Comodo Internet Security Premium software suite on our windows machines (which is free but comes with optional crud installs which you can opt-out of) plus Immunet 3.0 for an extra level of protection on top (free also).
31-12-2013 4:49 PM
Regards
Mike
09-02-2014 4:21 PM
I've been trying several different security packages over the last few weeks - and currently trying Bitdefender - which I find good.
The other one I have liked is BullGuard I quite liked - both are near the top of many surveys.
Mal
10-02-2014 4:06 PM
I bought it of ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=251401515596&ssPageName=ADME:X:AAQ:GB:1123
You can either wait for the cd to arrive to get the key, or they may offer to email key over to you, they did me.
Once you have the key download BDIS installer, and insert they key
http://www.bitdefender.com/site/Downloads/downloadInstaller/is.exe
Edit : Ah i see you already have the program, in that case just click licence info, enter the key,
Kind Regards
Mike
10-02-2014 4:15 PM
I'll be trying Bit defender for a week or so and then deciding which one to go for. So far Bitdefender seems to be doing well and is very unobtrusive.
Mal
10-02-2014 4:28 PM
Bullguard does not score as highly in the tests as BDIS, i would go with BDIS.
Regards
Mike
