McAFeePlusnet Protect does not display in a frame
albo42
I've installed Plusnet Protect from McAfee. When I select any of the features and select LEARN MORE, a new window opens and says its connecting to McAfee.com.......
then the page says:
READ OUR GUIDE
The page cannot be displayed in a frame.
To help protect the security of informaiton you enter into this website, the publisher of this content
does not allow it to be displayed in a frame.
Any ideas?
4 REPLIES 4
orbrey
Re: McAFeePlusnet Protect does not display in a frame
Is it possible to right click on the button for learn more, and copy the URL? If you can do that, just paste it into a new tab and it should work fine.
RobyMcAndrew
Same problem here. The link is in the McAfee UI, and it does not seem to support right-click.
McAfee Security Center Build 11.6.511
albo42
HI,
tried right-clicking to get the URL. AS Roby said, you cannot right-click. Any other suggestions most welcome. McAfee not even replied to my email yet !
albo42
Having had numerous issues with my PC since the install of McAfee e.g. high CPU , sluggish response, poor performance: I've removed the product and gone back to AVG
