Mc Afee livesafe
- Re: Mc Afee livesafe
Mc Afee livesafe
18-01-2016 8:35 PM
Hi I have bought a HP laptop which has McAfee LiveSafe installed free for a month.do I have to uninstall to install McAfee PlusNet protect or would it be possible to keep LiveSafe by using a serial number from plusnet protect saving the uninstall/install.
4 REPLIES 4
22-01-2016 1:45 PM
In my opinion you would be better to ditch McAfee all together. I don't like it and it's not popular with other regulars on this forum.
22-01-2016 2:47 PM
It seems that paid-for Anti-virus software gives the illusion of more security whereas running the likes of MSE/Windows Defender, in conjunction with Spy Bot S & D, Malwarebytes and CCleaner when their security definitions are updated regularly is just as good at preventing/removing infections
Forum Moderator and Customer
22-01-2016 5:47 PM
Agree Mav , i also believe Paid for AV gives a false sense of security .
Built in win10 AV plus as you say MWB ,Ccleaner you cant go wrong
22-01-2016 6:31 PM
Then again any AV is only as good as how it's used. At least once a week updating the definition files beforehand I would say is the minimum.
