May be one to delay the installation of until we see if there are any bugs
- May be one to delay the installation of until we s...
12-02-2010 1:57 PM
http://windowsteamblog.com/blogs/genuinewindows/archive/2010/02/11/windows-activation-technologies-u...
Windows Activation Technologies Update for Windows 7
8 REPLIES 8
Re: May be one to delay the installation of until we see if there are any bugs
12-02-2010 2:02 PM
What bugs in a M$ product never would I have believed it
Did you see the fiasco with the latest 13 patches for XP blue screening them?
12-02-2010 4:34 PM
I think Oldjim is talking about a "valuable" function whereby by M$ assume you nicked their software.
So it wants you to prove that you have paid for your buggy software.
In fact, it wants to repeat this process every 90 days - because M$ assume that you have to be a really muddleheaded idiot to have paid for this software.
12-02-2010 4:38 PM
Personal insults specially against moderators are good for a ban on these forums and calling me "a really muddleheaded idiot" should qualify
Now how do I ban Microsoft
12-02-2010 4:41 PM
It wasn't a personal insult, since the referent was Microsoft.
12-02-2010 4:49 PM
Thinks - how to get stripped of Moderator status and banned to boot.
Modify the swear filter to change Microsoft into "Only a really muddleheaded idiot would buy this"
12-02-2010 5:08 PM
Just been reading about it on El-Reg, it will be an "optional" install, a bit like the IE 8 it keeps trying to force on to my VM. Spyware by any-other name? Does that mean that if you don't install it then M$ will assume you have a pirate copy?? (Since it checks for the "bypasses", if you don't have them then it wont matter if you install it, will it?? ;))
I still like the Linux Genuine Advantage site
I know a couple of people who had their fully paid up copies banned "due to unforeseen circumstances" i.e. the M$ server going down!
18-02-2010 8:01 AM
Quote from: biker955 Did you see the fiasco with the latest 13 patches for XP blue screening them?
I've seen two computers where that happened and they both had a particularly nasty virus that had replaced the Windows atapi.sys file with its own version. I don't think its fair to blame Microsoft for an update that pushes virused computers over the edge. The problem is that this virus passes undetected by many scanners. You'll know you've got the virus when you do a search (Google or otherwise), click on a link and get taken to another destination than the web address associated with the link.
You should be able to banish the blue screen by using a Windows disk to boot the computer and replacing atapi.sys with the correct file.
18-02-2010 1:36 PM
I think that Microsoft should expect viruses to be there.
After all, it's their OS that let them in!
Why do they rely on bolt-on programs to try and block them?
