Manual uninstall
tynygongl
Manual uninstall
I have been removing a number of programs that came loaded on my computer which I do not want and with some, after running uninstall, I am told that not all parts have been removed and I should do this manually - how? Also, some programs I have removed still show in program lists but won't open etc.
6 REPLIES 6
drj
Re: Manual uninstall
Manual could just mean deleting the relevant directories
If by "program lists" you mean the start menu then you can right click and delete the shortcuts
shutter
Fixes: 65
you might also find there are still folders in your Program Files and Program Data, (under C drive) they should be empty,  check to make sure, so you can delete them
drj
Sorry - that's what I meant - I shouldn't still be referring to "directories"  Smiley
Mav
Fixes: 515
Running Ccleaner should help to get rid of broken registry links.
Forum Moderator and Customer
rongtw
Fixes: 12
windows uninstall always leaves stuff behind  Sad that why i use "revo uninstaller " nice free program
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
also as Mav says Ccleaner is excellent  Cool
tynygongl
Thanks to all replies; I think I've got the hang now.
