Malware Removal Forums
- Re: Malware Removal Forums
10-01-2009 2:15 AM
Sadly it appears that my PC has become infected with a rather persistant trojan called W32/AgentBypass.gen!K that is defying removal by my antispyware/anti-malware programs. Only Windows Defender detects it when my desktop loads up, but like the other programs, it doesn't see it on a full system scan.
I am aware of the existence of support forums who can help me through a process of removing this. However, please can people advise me which ones are the best for this.
Many thanks and kind regards, wanderyonder
10-01-2009 7:11 AM
a lot of other people are saying win defender doesnt work, the reason why are in the above Trend link, there reasons might get defender to do it
10-01-2009 10:49 AM
Can you advise your present antimalware system
10-01-2009 12:12 PM
Quote from: Oldjim Malwarebytes is always a good possibility for getting rid of nasty trojans http://www.malwarebytes.org/
At the time that infection was first detected, my anti-malware system consisted (in addition to Windows Defender) of Spybot - Search & Destroy, Lavasoft Ad-Aware and Zone Alarm Pro (with its Anti-Spyware element activated). My anti-virus program Avast 4.8 Home also has some anti-malware capability I understand.
Since I was alerted to the infection I have downloaded both SuperAntiSpyware and Malwarebytes' Anti-Malware.
With each of these (both the above existing and newly installed ones) I carried out a full system scan. None of them pick up anything other than the odd tracking cookie.
The alert only comes up when the desktop loads within my admin log-in. (I try to do most of my web browsing from within XP's limited account log-in.)
Hi pierre_pierre
Quote from: pierre_pierre trend Micro is a reputed virus info http://www.trendmicro.com/vinfo/virusencyclo/default5.asp?VName=BKDR_AGENT.DZQ&VSect=Sn how to detect and remove
Thanks for the link. That's useful. However, neither of the registry entries listed there are showing up on my system.
This is puzzling.
10-01-2009 12:16 PM
You could try this http://www.kaspersky.com/virusscanner
10-01-2009 1:41 PM
10-01-2009 3:43 PM
Quote from: Oldjim Possibly a false alarm from Windows defender - are there any other symptoms
Oldjim, I've not had any other alerts appear and I haven't noticed an affect on the performance or operation of the computer.
Kaspersky's online scanner picks up nothing too.
Quote from: Njal http://www.malwareremoval.com/
Regards,
Neil
Neil. Thanks for that link. I'll look into that.
Has anyone heard of http://www.bleepingcomputer.com? They appear to have a comprehensive forum there. Are they reputable?
10-01-2009 3:48 PM
10-01-2009 3:53 PM
18-01-2009 1:36 PM
http://www.bleepingcomputer.com/forums/index.php?s=&showtopic=193342&view=findpost&p=1084283
and
http://www.bleepingcomputer.com/forums/index.php?s=&showtopic=193167&view=findpost&p=1094381
It seems that a Windows Defender definitions update is seeing a part of Free Download Manager, called Free Uploader OE Integration, as a trojan. As far as I am aware, Free Download Manager is reputable and safe. I had a look at the start-up tab within my System Configuration Utility (MSConfig) and this Free Uploader was indeed listed. So within System Configuration, I disabled the Free Uploader from starting up and the Windows Defender warnings no longer appeared on boot-up.
I've uninstalled Free Dowload Manager version 2.5 which was causing this. I've since noticed that there is a more recent version available (v3) which I've installed. This new version appears to not add Free Uploader OE Installation to the start-up, when looking in System Configuration/Startup. A subsequent full system scan with all my anti-virus/anti-malware utilities gives me the all clear. And no more Windows Defender warning boxes so far.
So, hopefully, problem solved.
