Mail Timing Out on Windows Live Mail 2012
Bellagio
I use Windows Live Mail 2012 and I randomly keep receiving timeouts saying that my POP3 server has not responded in 60 seconds when I do a send/receive whereas other times it just goes straight through. This has only started happening since swapping to PlusNet. Any ideas how to stop this?
13 REPLIES 13
Fixes: 733
Re: Mail Timing Out on Windows Live Mail 2012
Hi there.
Can you confirm if you're using a Plusnet email address or a third party one?
Bellagio
It’s 3rd party (f2s) email.
Fixes: 733
Thanks for the confirmation.
Unless the community have any ideas on how to help, it's probably worth contacting the F2S to look into this.
From a staff perspective there isn't anything we can see in relation to a third party email address.
Hopefully the community users are able to provide more guidance or assistance though.
Fixes: 321
Moderators Note
This topic has been moved from Email to Tech Help.
Customer and Forum Moderator. Windows 10 Firefox 69.0.3 (64-bit)
Life is tough enough without adding Linux into the mix.
Bellagio
This worked fine when on Vodafone (up to 25th June 2019), it's just since switching to PlusNet which suggests it's a PlusNet issue.
Fixes: 733
Thanks for getting back to us. I don’t believe there’d be anything wrong with your broadband connection which would cause this unless you’re also experiencing problems in other areas too?
To narrow down where the issue may lie are you able to try the following:
  • Setup your emails on a different email client
  • Send mail from F2S’s webmail
  • Connect your computer to a different connection like a mobile data hotspot
Bellagio
Hi, I just tried and works fine on VPN and 4G mobile.
I made a separate post but the other thing that's weird is that Facebook and some YouTube comments just take ages to open (literally minutes) when I click on a post in Facebook but again they come straight through when using 4G.
Fixes: 733
Thanks for the update,
I suspect this may be IP address related, it’s possible that the IP you’ve picked up on may be blacklisted for some reason.
Can you switch your router off for around 65 minutes (Overnight if that’s not feasible for you to do this evening) and see if you’re able to send mail then?
Having said that, due to way the majority of dynamic IP addresses are assigned you may not get a different one but I think it’s worth a try.
Let me know how it goes, if you’re still having issues I’d be happy to dig into this again tomorrow when I’m back in the office.
Fixes: 733
Hi @Bellagio
Have you got this sorted yet? If you've not I'd like to add a static IP to your account which should change your IP address completely narrowing down where the issue may lie. Let me know how you got on.
Bellagio
It left it off for 8 hours on Weds but am afraid it’s still doing it. Trying a static ip would be great. I remember I had a similar problem a few years back when I had switched to plusnet and images on Facebook etc used to not load properly but it would just be a small cross. After multiple refreshes it would then work. Up until swapping to plusnet last month I was with Vodafone.
Fixes: 733
I’ll add a static IP onto your account when I’m back in the office tomorrow. If you want to try this sooner you should be able to add this via your account online for a one off charge of £5 which I’d be happy to credit off on this occasion.
Bellagio
Hi, the static ip seems to have fixed this issue.
Thanks again.
Fixes: 733
Hi @Bellagio
I'm firstly sorry for the delayed reply and not following up on the 10th.
I'm glad to see this is resolved for you now although you've not got a static IP however it does look like your IP changed to another dynamic one 3 days ago on the 10th in the evening.
Feel free to let me know if you need any further assistance.
