Mackbok running Win7/8 or Asus UX 305
- Mackbok running Win7/8 or Asus UX 305
17-05-2015 1:31 PM
University item.
Re: Mackbok running Win7/8 or Asus UX 305
17-05-2015 1:35 PM
17-05-2015 1:37 PM
17-05-2015 1:41 PM
17-05-2015 2:41 PM
Apple Part #: 661-5211A1322 77.5 watt hour
10.95V
77.5 WHr
Main Battery for Unibody MacBook Pro 15-inch
Mid 2009 & Mid 2010 Models
Manufacturers ID: A1321 020-6766-A
17-05-2015 2:48 PM
17-05-2015 2:49 PM
17-05-2015 2:51 PM
17-05-2015 2:53 PM
Quote from: 11110_110 The battery isn't cheap £150
What about a £30 ebay one?
http://www.ebay.co.uk/sch/i.html?_odkw=Battery+for+Unibody+MacBook+Pro+15-inch+A1321+020-6766-A&_osa...
17-05-2015 3:23 PM
17-05-2015 3:47 PM
17-05-2015 3:48 PM
17-05-2015 4:05 PM
17-05-2015 4:16 PM
You may need to do a bit of soldering....
17-05-2015 4:34 PM
I did look over the option of soldering some cells together about 12 months ago but just didn't warm to the idea, I also like the idea that the part I install will be perfectly safe for another person to use, yes I know it's an aluminium case etc.
