Macbook pro not booting
- Re: Macbook pro not booting
24-02-2015 3:01 PM
Done a reformat, still the same.
Using cmd+shift+v
boot-args = -v
** /dev/rdisk0s2 (NO WRITE)
** Root file system
Executing fsck_hfs (Version hfs-285
Blah blah.....
I/O error rdisk0s2
Then it hangs at the boot screen again with no progress at all.
24-02-2015 3:12 PM
see what that says.
24-02-2015 4:07 PM
24-02-2015 4:13 PM
disk1
OS X Base System
Appears to be OK.
Verify:
Macintosh HD
Appears to be OK.
24-02-2015 4:16 PM
Page with instructions that resolved issue so far: http://support.apple.com/kb/HT1379
power off
get ready with cmd-alt-P-R keys
power on
immediately press cmd-alt-P-R keys all togehter
release them when computer reboots
May need a PRAM batter replacement if that problem persists.
for example ebay £4.95
http://www.ebay.co.uk/itm/Apple-Macbook-Pro-15-4-PRAM-Battery-A1211-A1226-A1260-/261357612619?pt=UK_...
and tools £4.45
http://www.ebay.co.uk/itm/17in1-Screen-Repair-Open-Tool-Torx-Star-Super-Screwdriver-Set-Kit-Metal-Sp...
and instructions (awkward but not impossible)
https://www.ifixit.com/Guide/MacBook+Pro+15-Inch+Core+2+Duo+Models+A1226+and+A1260+PRAM+Battery+Repl...
24-02-2015 4:58 PM
@sjptd first thing I had a look at before the reformat, just tried again, still hanging
24-02-2015 6:13 PM
26-02-2015 6:15 PM
27-02-2015 1:58 PM
I put mine in the dishwasher and it wouldn't work any more.
27-02-2015 6:46 PM
WARNING do not put in dishwasher.
03-03-2015 7:27 AM
