Mac - PC emulator
Mac - PC emulator
Any recommendations for a PC emulator on a Mac.
Colleague of mine wants to run a GIS package (Mapinfo & Vertical Mapper).
Fixes: 182
Re: Mac - PC emulator
there are 2 options:
1) Crossover - http://www.codeweavers.com/products/ doesn't require an install of full windows but might have some compatibility issues.
2) Virtualisation - VMWare, Parallels or Virtuabox personally I prefer parallels
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
@dvorak:- Thanks will investigate further
