Mac OS X Exposé
tsphillips
Mac OS X Exposé
I have a Mac with OS 10.5.6.
When I either press the F3 key or simultaneously press the two buttons on the side of the mouse, all open windows are shown at once, in miniature. They used to appear in what I think of as a scrapbook-type format, i.e. in an array to fit the entire screen without overlapping but now they all appear very small, in a horizontal line across the middle of the screen - which I find less helpful. What can I do about it?
Re: Mac OS X Exposé
I'm afraid that I think you've hit upon a upon a recent bug in the Mac OS, as I've noticed the same thing happening occasionally too.
tsphillips
Re: Mac OS X Exposé
Thanks Be3G. FWIW, at first I experienced this problem only intermittently but now it always occurs.
adie:quote
ard126k
Re: Mac OS X Exposé
This happened to me (using 10.4.11) the fix was to alter the size of a window in normal view then Exposé worked 'properly' again. Hope it's the same in 10.5!
tsphillips
Re: Mac OS X Exposé
Your suggestion has worked for me, ard126k. Thank you.
