Mac OS X Exposé
- Re: Mac OS X Exposé
Mac OS X Exposé
23-03-2009 9:37 PM
I have a Mac with OS 10.5.6.
When I either press the F3 key or simultaneously press the two buttons on the side of the mouse, all open windows are shown at once, in miniature. They used to appear in what I think of as a scrapbook-type format, i.e. in an array to fit the entire screen without overlapping but now they all appear very small, in a horizontal line across the middle of the screen - which I find less helpful. What can I do about it?
4 REPLIES 4
Re: Mac OS X Exposé
23-03-2009 9:54 PM
I'm afraid that I think you've hit upon a upon a recent bug in the Mac OS, as I've noticed the same thing happening occasionally too.
Re: Mac OS X Exposé
24-03-2009 1:22 PM
Thanks Be3G. FWIW, at first I experienced this problem only intermittently but now it always occurs.
adie:quote
adie:quote
Re: Mac OS X Exposé
25-03-2009 12:04 AM
This happened to me (using 10.4.11) the fix was to alter the size of a window in normal view then Exposé worked 'properly' again. Hope it's the same in 10.5!
Re: Mac OS X Exposé
25-03-2009 8:11 PM
Your suggestion has worked for me, ard126k. Thank you.
