Mac/Linux keylogger
- Mac/Linux keylogger
Mac/Linux keylogger
31-08-2012 11:39 PM
looks like this is the source of the malware - just block this IP on your firewall
Re: Mac keylogger
01-09-2012 12:04 AM
Re: Mac keylogger
01-09-2012 12:24 AM
- "Web threat blocked: www whois-search com/?query=212.7.208.65&submit=Go"
couldn't get to the whois page!
bit weird
edit - oops, better break that link...
maybe the whois entry contains a link to a dodgy site
Re: Mac keylogger
01-09-2012 10:50 AM
Re: Mac keylogger
01-09-2012 12:22 PM
Re: Mac keylogger
01-09-2012 3:00 PM
NL Leaseweb are a constant source of aggravation!
212.7.192.0/18
edit -- is there a way to alter the title of a post? Wanted to make it 'Mac/Linux keylogger'...
Re: Mac keylogger
01-09-2012 7:32 PM
Quote from: IanSn is there a way to alter the title of a post? Wanted to make it 'Mac/Linux keylogger'...
Yes, just click Modify to the first post and the title should appear as an option to change it.
Re: Mac/Linux keylogger
01-09-2012 8:09 PM
doh!
(You seem to be getting into the habit of pointing out the obvious to me.... )
01-09-2012 9:05 PM
So all a cracker has to do is install them when you are not looking!
01-09-2012 10:19 PM
I was thinking a text file with all your logins and passwords. Just copy and paste such things without even touching the keyboard...
ok, thinking that for the want of something better to think....
Quote tells them which IP addresses to use in future
if it comes via EC2 there's nothing to block on your firewall (except the whole of Amazon), or ever find out where it actually came from
...I think I'll think about something else.....
01-09-2012 10:34 PM
For other sites, I sometimes enter incorrect characters, then correct, so any keylogger doesn't know the correct sequence.
05-09-2012 7:37 PM
06-09-2012 2:15 PM
It's designed to look difficult and therefore prove that any fault lies with you.
For example, it's obviously impossible to break a 4 digit numeric pin code - isn't it?
06-09-2012 9:11 PM
A right pain though given the requirement to always have the keyfob. For this reason I swtiched banks. I just hope they don't all end up adopting it!
Mathew
