Mac/Linux keylogger
IanSn
Mac/Linux keylogger
aimed at Mac/Linux users on Firefox, Chrome
212.7.208.65
looks like this is the source of the malware - just block this IP on your firewall Wink
13 REPLIES 13
IanSn
Re: Mac keylogger
also got a warning from this search string when looking up the IP on whois -
-  "Web threat blocked: www whois-search com/?query=212.7.208.65&submit=Go"
couldn't get to the whois page!
bit weird  Huh
edit - oops, better break that link...
maybe the whois entry contains a link to a dodgy site
ReedRichards
Seasoned Pro
Fixes: 25
Re: Mac keylogger
The more sophisticated Windows viruses access an online "server" that tells them which IP addresses to use in future (including the new server IP).  Surely it is only a matter of time before that capability is incorporated into this virus?
VileReynard
Fixes: 20
Re: Mac keylogger
It's not clear how this code gets executable rights in my user space - and how does it intercept inter-process calls between X and Firefox or whatever?
IanSn
Re: Mac keylogger
Hmm, turns out I already had this range blocked on htaccess after continuous single hits (into the hundreds) on the registration php file earlier this year from addresses across this whole range.
NL Leaseweb are a constant source of aggravation!
212.7.192.0/18  Angry
edit -- is there a way to alter the title of a post?  Wanted to make it 'Mac/Linux keylogger'...
RPMozley
Fixes: 13
Re: Mac keylogger
Quote from: IanSn
Yes, just click Modify to the first post and the title should appear as an option to change it.
That's RPM to you!!
IanSn
Re: Mac/Linux keylogger
doh!  Roll_eyes
(You seem to be getting into the habit of pointing out the obvious to me.... Grin )
VileReynard
Fixes: 20
http://code.google.com/p/logkeys/ lists some key loggers...
So all a cracker has to do is install them when you are not looking!  Grin
IanSn
Too easy, eh?
I was thinking a text file with all your logins and passwords. Just copy and paste such things without even touching the keyboard...
ok, thinking that for the want of something better to think....
if it comes via EC2 there's nothing to block on your firewall (except the whole of Amazon), or ever find out where it actually came from
...I think I'll think about something else.....
My First Direct bank login asks for random characters from my password, much better than typing the whole password.
For other sites, I sometimes enter incorrect characters, then correct, so any keylogger doesn't know the correct sequence.
AWB70
Am I right in thinking that this only can only work if someone has access to your keyboard or can it be installed by clicking a dodgy link? For my passwords I use LastPass which is integrated into chrome so that there's no need to type anything it auto fills and before that I used Keepass which also auto fills and deletes the info from cash within seconds of using it. My bank has an extra layer of security by having a key fob which generates a random sequence of numbers every time I login. Not sure how that works but it's probably a good thing.  Smiley
VileReynard
Fixes: 20
Unless your bank account gets stolen by an employee or some faulty banking IT.
It's designed to look difficult and therefore prove that any fault lies with you.
For example, it's obviously impossible to break a 4 digit numeric pin code - isn't it?  Roll_eyes
MJN
Fixes: 5
It's a fairly secure system, and effectively a time-limited one-time password.
A right pain though given the requirement to always have the keyfob. For this reason I swtiched banks. I just hope they don't all end up adopting it!
Mathew
