MX records not found for my exchange server
- Re: MX records not found for my exchange server
21-02-2014 7:59 PM
I've been waiting for 2 days for the setting to go through the internet, but everytime I to see if it sent, I get no mx record found.
Image I've added as an attachment, will show you the DNS settings on my DC/DNS Server. It's highlighted in an orange box.
21-02-2014 8:09 PM
21-02-2014 8:26 PM
21-02-2014 8:42 PM
Again, firstly, did this work before you changed server? Secondly,why did you need to change the MX record when you changed server (presumably your public IP address stayed the same?) and thirdly, what have the settings on your local server got to do with the problem?
21-02-2014 8:45 PM
21-02-2014 8:51 PM
3. Your local server is not set to be the nameserver for your domain (See previous post for servers that are). Note that if your local server was set as the authoritative server for your domain it wouldn't work either!
2. Your IP address hasn't changed therefore your MX record didn't need to be changed
1. Good - Back your changes out!
This is what the rest of the world sees for your domain.
21-02-2014 8:58 PM
What do you mean the mx record shouldn't change?
21-02-2014 9:01 PM
All you should have changed is the forwarding internally.
21-02-2014 9:07 PM
http://cse.unl.edu/~ylu/csce855/notes/OReilly-DNS-and-BIND.pdf
21-02-2014 9:15 PM
Image which i've attached
21-02-2014 9:40 PM
Currently, neither pop.ciscolabs.co.uk or smtp.ciscolabs.co.uk have and DNS records by the way!
21-02-2014 10:01 PM
as you can see it agrees with what others have posted, your mx settings are incorrect.
@pwatson the mx domains don't need A records
21-02-2014 10:09 PM
Quote from: dvorak @pwatson the mx domains don't need A records
Section 10.3 of RFC 2181 says it does (unless it's been superseded?)
22-02-2014 8:44 AM
However, you haven't created DNS records for pop.ciscolabs.co.uk or smtp.ciscolabs.co.uk so your config still won't work...
22-02-2014 9:11 AM
