MTU Settings In Windows 7 (solved)
- MTU Settings In Windows 7 (solved)
14-07-2010 3:30 PM
Re: MTU Settings In Windows (solved)
14-07-2010 3:59 PM
Sigh
B.
14-07-2010 4:23 PM
Re: MTU Settings In Windows 7 (solved)
14-07-2010 5:54 PM
14-07-2010 8:48 PM
27-07-2010 2:07 PM
27-07-2010 5:44 PM
27-07-2010 11:14 PM
iirc it can adjust it on the fly for the packet payload too.. its not a simple speed tweak anymore, its much more automated.
27-07-2010 11:48 PM
Quote from: Matt_2k34 ...........the network router (should be set to 1492 wan side anyway)...
Or should that be 1500? There is a post elsewhere on the forum that says changing 1492 to 1500 makes the difference between web pages not loading and loading.
28-07-2010 4:42 PM
TCP window size etc depends on free memory, error rate, transmission rate and latency of the remote connection - so that part should be dynamic, but who knows over what timescale?
Is it seconds, hours, reboots or what?
