MSConfig.exe
- MSConfig.exe
MSConfig.exe
19-10-2014 4:22 PM
Ok... When I start MSConfig it runs ok, but there is no default Operating System showing in the panel, in fact the panel is totally blank. This means that I can't perform any operations using MSConfig. Anyone any idea why the OS should be invisible and if there's a way to fix this?
I've never had any problems booting W7 so it seems to be getting recognised.
Re: MSConfig.exe
19-10-2014 4:29 PM
You need to go to
Accessories
System Tools
System Information
Or just search for System Information
This gives you everything you need
Using MSconfig then boot I get this
Re: MSConfig.exe
19-10-2014 4:37 PM
Re: MSConfig.exe
19-10-2014 4:39 PM
Re: MSConfig.exe
19-10-2014 4:52 PM
The one in the screenshot is for 32bit with onboard graphics
Re: MSConfig.exe
19-10-2014 4:55 PM
(And if it's 32- or 64-bit)
Re: MSConfig.exe
19-10-2014 5:00 PM
I can see the System Info but MSConfig just shows as in the attachment. So there's no OS to select and therefore no operations can be done. None of the buttons do anything.
I think there is an option to amend the RAM available in Boot>Advanced... but that will only work if an OS is showing.
Re: MSConfig.exe
19-10-2014 5:14 PM
Re: MSConfig.exe
19-10-2014 6:38 PM
64 bit and doesn't have on board graphics
Quote from: TORPC is yours 32bit or 64bit I know you have mentioned it elsewhere & can't remember where
How do you get that information from the screen shot
Re: MSConfig.exe
19-10-2014 7:13 PM
Re: MSConfig.exe
19-10-2014 7:53 PM
Quote from: Oldjim 64 bit and doesn't have on board graphics
The same way as you advised, earlier
Click start =====> Type System information =====> left click on System information in the results =====> wait for the System information to finish refreshing the info & scroll down if need be
That said I am using Win7 Ultimate (genuine) before anyone inquires
Re: MSConfig.exe
19-10-2014 8:04 PM
In post 1 I showed a screenshot from MSConfig
In post 4 you asked about Win 32 or 64 and said that my screenshot was for Win32 with on board graphics
So I repeat - from that screen shot how can you infer 32 bit or 64 bit and referring to System Information is irrelevant as I haven't posted anything from that
Re: MSConfig.exe
19-10-2014 8:21 PM
I meant that the screenshot was taken on a 32bit Win7 PC for comparison, not that the System information shows it is as 32bit PC
& trying to deduce why yours differed in post #3 "The interesting bit about mine is it can't tell the installed physical memory which may be down to the fact that the graphics card has 1GB
Re: MSConfig.exe
19-10-2014 8:30 PM
Re: MSConfig.exe
19-10-2014 8:35 PM
