MS Works problems
- Re: MS Works problems
MS Works problems
15-11-2010 9:15 AM
15-11-2010 10:28 AM
Is there an option to simulate XP ? (can`t remember the exact terminology..... but someone will...... )
15-11-2010 12:53 PM
15-11-2010 1:31 PM
15-11-2010 1:39 PM
15-11-2010 2:06 PM
15-11-2010 2:07 PM
15-11-2010 2:11 PM
15-11-2010 2:18 PM
This seems to be a frequent problem with files created on a USB connected hard drive by XP and then accessed on Windows 7 or Vista
The only solution I have seen which may work is to copy the folder to your normal drive and then copy it back again
I am not familiar with works but if it is the same as office it tries to create a temporary file in the same place as the original file
15-11-2010 2:21 PM
15-11-2010 2:23 PM
