MS Backup
morgan2476
MS Backup
This may be a daft question But does MS Backup compress the files it backs up?
3 REPLIES 3
MauriceC
Resting Legend
Fixes: 17
Re: MS Backup
Not in XP.    Sad
Don't know about Vista or Windows 7
morgan2476
Re: MS Backup
I have all my docs, photos etc on a partition to make it easier to backup. The backup file is smaller than the size of all the files on the drive, hence my question.
MauriceC
Resting Legend
Fixes: 17
Re: MS Backup
Most likely to be the minimum file size used for the disk(s).  Small disks may use a 1KByte minimum whereas larger e.g. 160GByte may use a 16K or even a 32K minimum block size.
So.  On one disk a 100 byte Notepad *.txt file shows up as 1K, but copy the file to a larger drive and it will show as 16K - no change in the data, just more empty space!
Maurice
