MAC addresses
MAC addresses
Hi
Is there a way to determine the MAC address of the wireless device attached to a computer, other than finding it printed somewhere on the outside, or relying on the DCHP list on the router?
Pendragon
Re: MAC addresses
One way is to open a command window and type
ipconfig /all
hit [return] and it should list all your adapters with their physical addresses.
Is this what you need?
Regards, P.
Re: MAC addresses
if you have a router and you are connected most of the routers will show who is connected and all so show the MAC address.
The util that comes with most devises also normally tells you
Re: MAC addresses
Thanks for both responses.  The command prompt works.  I was really thinking about attaching another computer to the network, and for some reason the DCHP on my router doesn't seem to pick up new computers all the time.
Thanks for the help guys
