Low cost telly
gleneagles
Aspiring Legend
Fixes: 17
Low cost telly
Just purchased a low cost telly (£99.99) from Aldi with 3 year guarantee, picture & sound are ok for the money,  inputs include scart, usb, rs232,hdmi, plus a load of others.
I Have no need to use it as a monitor and if I wished to do so it would be just a matter of plugging in the RS232 cable but what's the usb port for ?
Is it just to play back stuff just recorded on the computer and if so is there any way I can set up (as cheaply as possible) some sort of cordless connection to allow me to play stuff on the TV. ? would a bluetooth connection work ?
We are born into history and history is born into us.
6 REPLIES 6
artmo
Aspiring Champion
Re: Low cost telly
Maybe this answers your USB query:
Coming with a built-in DVD player, the Sharp LC22DV510K is ideal for anywhere where space is tight. In addition to the built-in DVD player, the LC22DV510K comes with a versatile USB socket. Not only will this let you playback video, audio and photos but its two-way capability allows you to record, too. Simply connect up a suitable hard drive and you can use it like a PVR (Personal Video Recorder) to record all your favourite TV programs. You'll also find an HDMI socket that's perfect for connecting a Blu-ray player or HD games console. SCART, component and a PC socket are included, too. For private listening there's also a headphone socket. Finally, a coaxial digital output lets you plug the TV into a digital audio system for enhanced sound.
Oldjim
Resting Legend
Fixes: 63
Re: Low cost telly
My TV has a USB slot and it is used for upgrading the firmware
shutter
Fixes: 65
Re: Low cost telly
I have one of these .....
http://www.ebay.co.uk/ctg/EvoDigital-Premier-8-GB-Digital-Media-Player-/113325752?_refkw=touch+scree...
which I use in the car, to entertain myself, while `er indoors is shopping.....  Roll_eyes
I mostly have music videos, which I sometimes watch on the TV, by plugging in the "download" connector, to the USB slot on the tv... works brill... nice to see the artistes on BIG  screen with a decent sound system provided by the tv speakers.
Strat
Fixes: 565
Re: Low cost telly
My next door neighbour has a cheap LCD TV in the kitchen. It has a USB port into which is plugged a memory stick.
He records programs on it for later viewing.
w23
Fixes: 4
Re: Low cost telly
Some of the Technika (Tesco Brand) TVs have a USB socket, on some models you can record but others will only playback files recorded on a PC or similar.
Do the instructions not give any clues?
Call me 'w23'
ReedRichards
Seasoned Pro
Fixes: 25
Re: Low cost telly
Quote from: gleneagles
No. but you probably mean VGA in which case yes.  My (limited) experience  with TV monitors is that they don't necessarily support a wide range of display resolutions.
My TV will play audiovisual files on a USB stick.(but not record)
