Lost wifi connection on Android
bucklnwr
My Android tablet has lost the connection to my wifi.  It finds the network with excellent signal strength, but when I enter the router password, it reports 'Authenticating'.  After a while it closes the app but does not connect.  I have entered both the router password and tried the Wireless Key, but neither appear to solve the problem.  I have two other android devices, fortunately they will connect without any problem.  Where is the fault and what can I do about it?
2 REPLIES 2
Browni
Aspiring Hero
Fixes: 60
Re: Lost wifi connection on Android
First thing to try is forgetting the Wifi network and trying to connect again. Normally you can do this with a long press on the network name and selecting forget network.
bucklnwr
Thanks.  That worked.
