Lost Favourites on IE7 - SOLVED - thanks Samuria
repcomms
One of my PCs crashed the other day and had to get it rebuilt at great cost.  Got all the software backed up but unfortunately I lost all my IE7 favourites.
Is it possible to import the list from another machine much the same as Foxmarks can synchronise bookmarks on Firefox ?
Bob
6 REPLIES 6
Mav
Fixes: 515
Re: Lost Favourites on IE7
I simply go to Documents & Settings then select the correct <user> account and copy the Favourites folder to a backup folder on another drive then copy it back when required. HTH.
Forum Moderator and Customer
samuria
In IE under file menu there is import and export which lets you transfer both favorites and cookies. On the other pc you use the same and import.
Mav
Fixes: 515
I never noticed that. Will make things easier in the future. Cheers.
repcomms
Thanks Samuria, worked a treat.  Problem SOLVED reported in line with your other posting Smiley
Judging by the number I imported from my other machine across the network I think it is time for a cull !
cheers
Bob
pierre_pierre
Just a thought as you are the original poster can you alter the thread title to include solved  - Tah
repcomms
Re: Lost Favourites on IE7 - SOLVED - thanks Samuria
Thanks Pierre - good point - done  Wink
