Loss of sound
sweafe
Loss of sound
i plugged my iphone into my pc for the first time the other night and since then i am unable to get the sound on my pc working  Sad
any ideas?
sharpyuk
Re: Loss of sound
Check in your sound properties (either via control panel or right clicking the volume icon near the clock) and ensure that your "Playback Device" is set to your internal speakers.  Second.. check its not on mute Smiley silly i know, but you will be amazed Tongue
sweafe
Re: Loss of sound
haha yeah its not on mute
im at work at the moment like so i will try it later
the speaker icon has gone though  Huh
sharpyuk
Re: Loss of sound
If the speaker icon has gone then it could be that the device is not loaded or the driver is corrupt.  Try my suggestion above first re control panel (that should have a checkbox to enable the speaker icon).
It might also be worth right clicking on your 'my computer icon" properties then once the box comes up, find the device/hardware section (will differ depending on OS)... have a look through near the bottom of the tree displaying all your types of hardware for the Sound.... see if your Soundcard is shown in there..  If so, right click, uninstall and reboot the PC.
With any luck it will re-install and the hardware will be fine, or you will find it is disabled (red line through it) in which case you can right click, enable..
Fixes: 24
Re: Loss of sound
When you plugged in your IP phone you gave your computer a choice of speaker outputs it never had before.  It could output sounds to your normal speakers or it could output sounds to the exciting new speaker in your IP phone.  The chances are it has chosen to send all sound output to the speaker in your IP phone (when plugged in) and nowhere otherwise.  Some fiddling with the settings is called for.
sweafe
Re: Loss of sound
ha its ok it started working again by itself when i turned my pc on last night  Crazy
lol thanks for your help anyway guys  Smiley
sharpyuk
Re: Loss of sound
That confirms it then.... it was on mute all along Tongue
Lurker
Re: Loss of sound
Quote from: sharpyuk
[...]it was on mute[...]
Is 'on mute' the same as 'off sound'?
Fixes: 193
Re: Loss of sound
I thought the Mute was carried across a Power Down or re-boot. It does for me.
Forum Moderator and Customer
sweafe
Re: Loss of sound
haha noo it wasnt on mute
i checked the other night when it first happend and it defo wasnt
i dunno what it was tbh
but it started working again last night anyway  Tongue
