Loss of network access after sleep in Windows 7
- Loss of network access after sleep in Windows 7
- « Previous
- 1
- 2
- Next »
Re: Loss of network access after sleep in Windows 7
09-07-2013 10:01 AM
How silly is this
Just checked this morning and I can see the other computer on the network and the router - BUT not my computer
However the XP computer can still see my computer
As long as my computer can see the other one the automatic back will work and also file sharing so I don't care
09-07-2013 7:34 PM
There was an issue on Vista where 0.0.0.0 got added as a default route under some conditions. There does seem to be some reports of it happening sometimes on 7. Next time you have a problem Jim, can you post the output from an ipconfig/all . You may need to send the output to a file and then post the contents as described here http://community.plus.net/forum/index.php/topic,116416.msg1005752.html#msg1005752
09-07-2013 8:03 PM
Will do
- « Previous
- 1
- 2
- Next »
