Looking for help re: security & passwords for Voyager 2091 please...
pootle
I think my router only has WEP so thought I'd better look at getting WPA however, when I go into my router using IP add or http://voyager.home, it automatically signs me in but if I try to access any advanced menus ie security, it asks for a login & password again.  I have tried both my account username/password and my BB username/password (<username>@plusdsl.net) and neither is working.  I have these written down and as far as I'm aware have no others, does anyone have any advice?
jnwright
Re: Looking for help re: security & passwords for Voyager 2091 please...
According to the PlusNet Voyager 2091 helpfile both usename and password are set by default to admin
pootle
That worked, thanks a lot!
pootle
Now I just need to know how to change to WPA...  I'm in Wireless Encryption Settings and have changed to WPA-PSK, Data Encryption has defaulted to TKIP??  and it looks like I need to put in a Pre-Shared Key?  Can anyone advise me here please?
pootle
Sorted at last, downloaded a key generator and am now on WPA - great.
jnwright
You beat me to post!  I'll still send this in case anyone else is interested!
There are a few notes on this.
There is a site which will generate a random password for you or you could use the WEP one on the bottom of the router if no-one has already cracked it!
