Looking for help re: security & passwords for Voyager 2091 please...
- Looking for help re: security & passwords for Voya...
20-01-2008 9:28 PM
I think my router only has WEP so thought I'd better look at getting WPA however, when I go into my router using IP add or http://voyager.home, it automatically signs me in but if I try to access any advanced menus ie security, it asks for a login & password again. I have tried both my account username/password and my BB username/password (<username>@plusdsl.net) and neither is working. I have these written down and as far as I'm aware have no others, does anyone have any advice?
5 REPLIES 5
Re: Looking for help re: security & passwords for Voyager 2091 please...
20-01-2008 9:44 PM
According to the PlusNet Voyager 2091 helpfile both usename and password are set by default to admin
20-01-2008 9:59 PM
That worked, thanks a lot!
20-01-2008 10:08 PM
Now I just need to know how to change to WPA... I'm in Wireless Encryption Settings and have changed to WPA-PSK, Data Encryption has defaulted to TKIP?? and it looks like I need to put in a Pre-Shared Key? Can anyone advise me here please?
20-01-2008 10:38 PM
Sorted at last, downloaded a key generator and am now on WPA - great.
20-01-2008 10:47 PM
You beat me to post! I'll still send this in case anyone else is interested!
There are a few notes on this.
There is a site which will generate a random password for you or you could use the WEP one on the bottom of the router if no-one has already cracked it!
