Looking for a text-search utility
- Re: Looking for a text-search utility
23-11-2010 12:27 PM
Hi
Can anyone recommend a good text-search program that can search text files inside a compressed CAB archive file? I have tried Examine32 which finds text inside ZIPs, but it doesn't work with CABs. Unfortunately, I can't change the CAB file type, so I need to find a better search utility.
Thanks!
Thanks!
1 REPLY 1
23-11-2010 1:53 PM
Just done a quick "google" and came up with this page.... don`t know if it is any good for you....
http://www.thefreecountry.com/programming/searchandreplace.shtml
