Looking for a text-search utility
KenA
Hi
Can anyone recommend a good text-search program that can search text files inside a compressed CAB archive file?   I have tried Examine32 which finds text inside ZIPs, but it doesn't work with CABs.  Unfortunately, I can't change the CAB file type, so I need to find a better search utility.
Thanks!
1 REPLY
Fixes: 19
Re: Looking for a text-search utility
Just done a quick "google" and came up with this page.... don`t know if it is any good for you....
http://www.thefreecountry.com/programming/searchandreplace.shtml
