Looking for a Firefox add-on...
- Re: Looking for a Firefox add-on...
10-03-2008 9:23 AM
Many of you seem to be using Firefox, so I was wondering if someone might help me find the add-on I have been searching for with no success.
I have an unusually extreme form of motion sickness, and any movement on a web page makes me nauseous (e.g. the <- M or the "Cheesy" smiley on the Start new topic page which I am using right now).
I already have Adblock and Flashblock installed, but it is not enough, as most sites have a scrolling news/weather/finance banner, and god knows what other moving object on the page.
So, to cut a long story short, do you know of an add-on that stops movement on a page?
Many thanks!
Many thanks!
8 REPLIES 8
10-03-2008 11:14 AM
Tam found this:
http://labnol.blogspot.com/2007/08/how-to-stop-gif-image-animations-from.html
In summary, hit escape in Firefox and it will stop gif animation. If you want to do it permanently, you can turn it off from a value in about:config. Details on that page!
Kelly Dorset
Ex-Broadband Service Manager
10-03-2008 11:34 AM
That is absolutely incredible! Many thanks for the tip, I am delighted!
10-03-2008 11:40 AM
You could try this too:
http://www.siliconmethod.com/firefox/anidisable/
Kelly Dorset
10-03-2008 11:51 AM
Thanks, but it is so simple to just hit the escape key...
I am glad that this line of smileys has finally stopped making me sick. Wasn't so bad with the old ones, perhaps because they were smaller...
10-03-2008 1:36 PM
Learn something new every day. That is why I love Firefox, always something funky you can do with it!
10-03-2008 1:56 PM
Do you know this one: Toolbar Buttons 0.5.0.1?
I installed it yesterday and it's got loads of options. Really cool!
In fact, there is something called "Toggle Animation", but I don't know what "toggle" means in this context...
Perhaps I should try it to see what it does!
10-03-2008 2:30 PM
Quote from: BlueRhizome but I don't know what "toggle" means in this context...
If it's off turn it on and if it's on turn it off.
10-03-2008 4:03 PM
Ah well, of course! Thanks! Will give it a try.
Edit: Works very well. Means I don't have to disable animations permanently, so the rest of the family can 'enjoy' them.
