Login details will not autofill
chippy777
Since the upgrade to squirrel mail my login details will not autofill.  I have contacted support who suggested checking history delete etc.. but all is as should be (no delete on exit).
Can anyone advise please?  It is a pain having to enter ID and password everytime I want to check my email.
Thanks!
1 REPLY
Fixes: 62
Re: Login details will not autofill
which browser are you using
