Location of sound recorder files?
chuffchuff
I have recorded into the Sound Recorder files on 8.1.
Where are the files stored so I can move them?
I cannot email them using Windows mail, so short of copying them onto
my Windows phone and then back again into a folder is there anything
else I can do to locate them?
Any suggestions as to a more user friendly sound recording software to use on
8.1?
2 REPLIES 2
shutter
Fixes: 64
Re: Location of sound recorder files?
If you know the file TYPE..    e.g.  .mpg  or .wma  just put that into the search box above the START button... and it should bring up the files with that  type ... careful,... you can "open file"  .;... or Open File Location... which is the one you want.... probably lurking at, or near the bottom of the list..
twocvbloke
The answer:
http://bfy.tw/21jO
