Local number and VOIP
FlossyThePig
When I upgraded to FTTP I ported my landline number to A&A for their VOIP service.
Yesterday while chatting to our next door neighbour she said she tried to phone us (on our landline) and got number not available or a similar fault.
She would have just dialled our number without the area code.
The simple question is: does Openreach add the area code or does the system treat any number without the area code as local?
5 REPLIES 5
Mustrum
Fixes: 81
Re: Local number and VOIP
As you are no longer directly connected to your local exchange, anyone calling you will need to add the area code.
There are a few areas that everyone has to add the area code, Poole/Bournemouth as an example.
RobPN
Fixes: 15
@FlossyThePig
REMOVED.
Edit:  @Mustrum types faster than me!
Edit2: And gave a better explanation!
FlossyThePig
Thank you for the replies, which is what i thought.
I wonder what will happen after PSTN is switched off.
Fixes: 583
Some (most?) voip devices can have the local std code preset, so dialling a number that doesnt start with 0 will automatically have the local std code prepended to the number.
My Gigaset N300IP certainly has the facility.
I suspect ISP supplied digital voice systems will possibly be setup this way.
"There are a few areas that everyone has to add the area code, Poole/Bournemouth as an example."
Here in Milton Keynes, we have had to dial the full number on local calls for quite a few years now,
I think it is to do with some areas running out of telephone numbers, and doing this releases more of them?
I have noticed that since this change, there are quite a few local businesses advertising landline numbers beginning with a "9".
