Local Disk (F:) weirdo
- Local Disk (F:) weirdo
10-06-2018 4:21 PM
I have a usb SATA/IDE caddy.... When it works, it works fine..... It is about 5 years old... and used to give no problems. HOWEVER !!!!!
recently, in the past 6 months or so..... plug in a hdd.... plug in to a USB port.... and wait..... naff all shows.... on pulling the plug, suddenly it shows ! ... but... "GOTCHA" takes over... and because I pulled the plug... it is not showing. nor... does it "re-show" when plugged back into the USB slot.
I have gripped the small usb connector, on the pcb, with a pair of long nose pliers, to make it a more "firm" hold/connection... which seemed to have worked..... HOWEVER ! ! ! !.
after it has been showing, and in use for a while...( say, about an hour )... it suddenly disappears... No... it has not been moved, so it is not a "dodgy" usb connection... If I unplug it.... when I plug it back in again... it gives a message..... USB DEVICE NOT RECOGNISED ! ! ! WOT ? it was recognised and in use for the last hour... so ? ? ? [-Censored-] ? ? again... unplug... try anothe usb port... not recognised.
leave it plugged in.... naff all... unplug it again.... same usb port... wait a while, and HEY PRESTO !... it shows and is working... .... as before... after a while it disappears... then re-appears without doing anything to it whatsoever...
So.... anyone any ideas what is happening..... ? ? and how to ensure it works as it should do...i.e. "plug n play".... ? ?
oh ... just so you know... this was on a "new install" of Windows 7 Professional in January this year....
and again... on a new hdd... new install Yesterday... all drivers downloaded and installed from Dell...
And I have used different USB connector cables.... same problems... !
Re: Local Disk (F:) weirdo
10-06-2018 5:20 PM
Presumably when you pull the plug you are using Safely Remove Hardware and Media before doing so? Is the HD USB 2.0 or a 3.0. I've found sometimes just swapping it from one to the other gets the computer in a twist, such it wants to re-install the thing. Just pulling it out can corrupt things, even more so if it is still writing to it.
And I know I have a USB port that is, to put it mildly, slightly worn. I did it the other way, closed up the socket, however it isn't a cure all. Move the phone and all I get is disconnect, connect, disconnect noises. I've toyed with renewing the socket but I have plenty of others to play with.
10-06-2018 5:47 PM
No,... I have always pulled the plug... it`s supposed to be "hot" to do it with this thing... so no problem in the past .... it is supposed to be USB 2.0 but I also have a USB 3.0 slot... and it works ( when it wants to ) in either... as a matter of fact, it is in the USB 3.0 slot now, and still seems to be working.... as the title says.... "weird" ! ! .
11-06-2018 2:40 AM
11-06-2018 2:53 AM
Does the USB caddy have its own standalone power supply? If so, that could be failing, it's 5 years old and some things don't last as long as they should!.
I know my Inateck 2xSata docking station has quite a hefty PSU, which I have sometimes used as a substitute when checking to prove/disprove other suspected PSU failures (e.g.routers etc.).
11-06-2018 8:28 AM
@RobPN No, it does not have a separate power supply.... there is a facility to power it using a usb power cable. I have tried using that in conjunction with the usb signal cable, but made no difference to the "not recognised" or "not seen" situations..
Another "weirdy" I forgot to mention.... sometimes when I plug it in... ( as I have just now )...it gives the message
"You need to format the disk in drive F: before you can use it.
Do you want to format it"!
Format Disk Cancel..
Just showed me 8 of those messages.... so I unplugged it, and re plugged it... and get the"Autoplay" window about Viewing files & folders ! !
Obviously it has "seen" the disk.... so it is "recognised" ! ... and No... I don`t want to format it... cos I know it`s OK and I want to get the info off it first, thankyou very much ! ! ! !>
11-06-2018 2:09 PM - edited 11-06-2018 2:13 PM
Have you tried the disk in a different PC or laptop?
Also, why does it say drive F?
11-06-2018 2:20 PM
I would agree the caddy could be on the way out.
Usual sugesstions is make sure all your data is backed up. etc.
Try a different cable to rule that out. Other thing to try is the mobo USB port. Try a memory stick and see if that causes any intermittent problems.
11-06-2018 5:40 PM
It shows as disk F: because I have other drives in use ... not connected with this problem.
The whole idea of having the caddy and the hdd in it, was so that I could transfer all the stuff on it, onto a new install of Win 7 pro... and that would make the caddy/hdd the "back up"...
I did purchase another "similar" caddy because I thought it may be faulty,... but that one failed to show when connected to any usb port... it had a driver disk for W95 ... so I told the seller, and he has said to send it back... waiting now for the refund.
11-06-2018 7:08 PM
Caddy's don't need drivers - do they?
12-06-2018 10:23 AM
Maybe it was a USB driver. We are talking 23 years ago.
The drive may well be capable of 'hot swapping ' but I wouldn't care do it with memory devices that might be writing in the background.
Have you considered updating/reinstalling your USB driver?
12-06-2018 3:41 PM - edited 12-06-2018 3:42 PM
I didn`t ask for stupid comments either... please desist... you are not funny.
12-06-2018 3:46 PM
@Baldrick1 Yes, indeedy.... all my drivers have been updated... I have just done a "Clean Install" of Win 7 Pro from a dvd... and all updates have been installed... Also, I have been through the "system" list and double checked all the drivers are the latest versions installed.
Having tried various combinations of usb input points, and various ( miscellaneous ) cables, checking against other usb hardware, I have come to the conclusion that the caddy must be faulty, and have just ordered another one from eby... Hopefully, it will arrive on Monday/Tuesday next week,... and I can finally ditch this troublesome unit ! ! ..
Thanks for all the helpful suggestions and information.... to those people,. Much appreciate your time and effort..
consider this now closed.
12-06-2018 4:05 PM
Moderator's note:
Topic locked at OP's request.
