Local Disk (F:) weirdo
shutter
Fixes: 65
I have a usb SATA/IDE caddy.... When it works, it works fine..... It is about 5 years old... and used to give no problems.  HOWEVER !!!!!
recently, in the past 6 months or so..... plug in a hdd.... plug in to a USB port....  and wait.....   naff all shows....  on pulling the plug, suddenly it shows  !  ... but... "GOTCHA" takes over... and because I pulled the plug... it is not showing.   nor... does it "re-show"  when plugged back into the USB slot.
I have gripped the small usb connector, on the pcb, with a pair of long nose pliers, to make it a more "firm" hold/connection... which seemed to have worked..... HOWEVER ! ! ! !.
after it has been showing, and in use for a while...( say, about an hour )... it suddenly disappears... No... it has not been moved, so it is not a "dodgy" usb connection...    If I unplug it.... when I plug it back in again... it gives a message..... USB DEVICE NOT RECOGNISED  ! ! !   WOT  ?   it was recognised and in use for the last hour... so  ? ? ?  [-Censored-] ? ?    again... unplug... try anothe usb port...   not recognised.
leave it plugged in.... naff all... unplug it again.... same usb port... wait a while, and   HEY PRESTO !... it shows and is working... .... as before... after a while it disappears... then re-appears  without doing anything to it whatsoever...
So.... anyone any ideas what is happening.....  ? ?  and how to ensure it works as it should do...i.e. "plug n play"....  ? ?
   oh ... just so you know... this was on a "new install" of Windows 7 Professional in January this year....
and again... on a new hdd... new install Yesterday... all drivers downloaded and installed from Dell...
And I have used different USB connector cables.... same problems... !
13 REPLIES 13
idonno
Champion
Fixes: 6
Re: Local Disk (F:) weirdo
Presumably when you pull the plug you are using Safely Remove Hardware and Media before doing so? Is the HD USB 2.0 or a 3.0. I've found sometimes just swapping it from one to the other gets the computer in a twist, such it wants to re-install the thing. Just pulling it out can corrupt things, even more so if it is still writing to it.
And I know I have a USB port that is, to put it mildly, slightly worn. I did it the other way, closed up the socket, however it isn't a cure all. Move the phone and all I get is disconnect, connect, disconnect noises. I've toyed with renewing the socket but I have plenty of others to play with.
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
shutter
Fixes: 65
No,... I have always pulled the plug... it`s supposed to be "hot" to do it with this thing... so no problem in the past ....  it is supposed to be USB 2.0   but I also have a USB 3.0 slot... and it works ( when it wants to ) in either...    as a matter of fact, it is in the USB 3.0 slot now, and still seems to be working.... as the title says.... "weird"  ! ! .
RPMozley
Fixes: 13
The USB HDD caddy might be on the blink. Best check it out next, either by trying another disk installed or trying the disk in a different caddy (if you have one).
That's RPM to you!!
RobPN
Fixes: 13
@shutter
Does the USB caddy have its own standalone power supply?  If so, that could be failing, it's 5 years old and some things don't last as long as they should!.
I know my Inateck 2xSata docking station has quite a hefty PSU, which I have sometimes used as a substitute when checking to prove/disprove other suspected PSU failures (e.g.routers etc.).
shutter
Fixes: 65
@RobPN No, it does not have a separate power supply.... there is a facility to power it using a usb power cable.   I have tried using that in conjunction with the usb signal cable, but made no difference to the "not recognised" or "not seen"  situations..
Another "weirdy"  I forgot to mention.... sometimes when I plug it in... ( as I have just now )...it gives the message
"You need to format the disk in drive F: before you can use it.
Do you want to format it"!
Format Disk   Cancel..
Just showed me 8 of those messages.... so I unplugged it, and re plugged it... and get the"Autoplay" window about  Viewing files & folders  ! !
Obviously it has "seen" the disk.... so it is "recognised" ! ... and No... I don`t want to format it... cos I know it`s OK and I want to get the info off it first, thankyou very much ! ! ! !>
VileReynard
Fixes: 20
Have you tried the disk in a different PC or laptop?
Also, why does it say drive F? Crazy3
Alex
Fixes: 13
I would agree the caddy could be on the way out.
Usual sugesstions is make sure all your data is backed up. etc.
Try a different cable to rule that out. Other thing to try is the mobo USB port. Try a memory stick and see if that causes any intermittent problems.
shutter
Fixes: 65
It shows as disk F: because I have other drives in use ... not connected with this problem.
The whole idea of having the caddy and the hdd in it, was so that I could transfer all the stuff on it, onto a new install of Win 7 pro... and that would make the caddy/hdd the "back up"...
I did purchase another "similar" caddy because I thought it may be faulty,... but that one failed to show when connected to any usb port... it had a driver disk for W95 ... so I told the seller, and he has said to send it back... waiting now for the refund.
VileReynard
Fixes: 20
Caddy's don't need drivers - do they?
Fixes: 417
Maybe it was a USB driver. We are talking 23 years ago.
@shutter
The drive may well be capable of 'hot swapping ' but I wouldn't care do it with memory devices that might be writing in the background.
Have you considered updating/reinstalling your USB driver?
shutter
Fixes: 65
@VileReynard
I didn`t ask for stupid comments either... please desist... you are not funny. Angry
shutter
Fixes: 65
@Baldrick1  Yes, indeedy.... all my drivers have been updated... I have just done a "Clean Install" of Win 7 Pro from a dvd... and all updates have been installed... Also, I have been through the "system" list and double checked all the drivers are the latest versions installed.
Having tried various combinations of usb input points, and various ( miscellaneous ) cables, checking against other usb hardware, I have come to the conclusion that the caddy must be faulty, and have just ordered another one from eby... Hopefully, it will arrive on Monday/Tuesday next week,... and I can finally ditch this troublesome unit ! ! ..
Thanks for all the helpful suggestions and information.... to those people,. Much appreciate your time and effort..
consider this now closed.
Strat
Fixes: 565
Moderator's note:
Topic locked at OP's request.
