Linux webserver uptime.
- Re: Linux webserver uptime.
07-05-2009 9:24 PM
Specs:
Centos 4.7, Apache, Webmin Proftp etc etc
Dual PIII 1Ghz
768Mb SDRAM
Dual 2 Gb IDE HDD
4Gb IDE HDD
80GB IDE HDD
07-05-2009 11:13 PM
If there are no clues there, then it's likely a hardware problem.
B.
08-05-2009 9:20 AM
New box has been up for 81 days and 14 hours
08-05-2009 10:49 AM
08-05-2009 10:54 AM
Currently, my colo server is showing 206 days uptime
B.
08-05-2009 4:46 PM
And re: Chilly, Solaris is a hardened OS and is tested to destruction so it is pretty damn solid. Add that to the high quality hardware Sun uses in it's kit (especially the SPARC stuff) and it becomes pretty bombproof. Nothings perfect though and we do occasionally get hardware failures, although the vast majority of these are disks which get stressed a fair bit.
08-05-2009 5:10 PM
I'm often surprised at how long "cheap" servers made up from off the shelf parts from Maplin actually stay up
08-05-2009 5:56 PM
08-05-2009 9:06 PM
That's why we use it, peoples lives quite literally depend on it!
We have seen a few power supply failures over the years, (early Ultra5's), but an occasional vacuum, works wonders. But then I guess your stuff is in a nice dust free data centre.
08-05-2009 10:29 PM
22-05-2009 10:35 PM
I mainly blame a cheap (defective) 68 conductor cable connecting my 72GB SCSI drive with the HBA.
So I (reluctantly) parted with about £80 for a 1TB SATA drive which rotates at half the speed - although it's slightly quieter.
I now have a drive that has 85% unallocated space - the whole situation is ridiculous.
When I started work, we had a mainframe that filled a room and had two 30MByte exchangeable disk units - each one bigger than my washing machine.
23-05-2009 3:22 PM
23-05-2009 3:43 PM
adie:quote
