Linux security
- Linux security
Re: Linux security
07-08-2012 11:29 AM
Quote from: petertuson I also ran an intrusion detection system which flagged up all the bits of linux that enables interoperability with windows so I turned them off.
Can you provide a bit more info about the intrusion detection system or what problems might be caused by interoperability with Windows.
If it's very detailed a link to a site with this info would be helpful.
dick:green Quote fixed
Re: Linux security
07-08-2012 5:11 PM
Quote from: Waldo waldo@schabziger ~ $ sudo bash
Using sudo to run bash, what kind of world is this.. Any self respecting Linux install will have the su command!
The only time I ever login as root is when a kernel update has killed the NVidia drivers and they need rebuilding or doing serious system management.
Re: Linux security
07-08-2012 5:47 PM
Re: Linux security
07-08-2012 6:46 PM
Re: Linux security
07-08-2012 7:58 PM
I am allergic to Command Line use (or just to old to learn it!) , and so value the simple "boot to root" option in PCLinuxOS.
Am I not right in thinking that it is perfectly safe off-line?
Re: Linux security
07-08-2012 9:42 PM
Running as root off line would limit the ability for any malicious script/program to contact external servers but will make no difference to the damage they can cause to your system.
The main concern running X as root is usually the damage that badly coded apps or inexperienced users can cause.
Also, it wouldn't make any practical difference whether you run a full X session as root or an individual X app with root privileges, they can both cause equal amounts of damage.
And don't forget, while a malicious script or program run as a normal user can't trash your system, it can trash your user data, which is usually more important.
Re: Linux security
10-08-2012 6:44 AM
Quote from: Heloman https://www.grc.com/discussions.htm
Is there any particular reason why so many threads take place on grc.test?
Re: Linux security
10-08-2012 6:44 AM
Re: Linux security
23-08-2012 12:09 PM
Something else I am curious about, still security related what do linux users do about ip filters when using Torrent apps and IP filters. I notice block list is now only for donators but you can get a tar text file. Is there some way of converting this text into something that can be used with QBtorrent? I notice that Transmission doesn't seem to have the ability to ip filter any more or I can't seem to find the edit preferences button I've been using Torrents more these days after installing Virtualbox to try a few flavours.
Ironically blocklist filters are being seeded but this is definitely not the route to go down oohh the irony. Some may say poetic justice!
Re: Linux security
23-08-2012 2:14 PM
If you wanted to infect Linux, the best way would be to create a modified distro and hope that the user didn't bother to do a md5 check on the .iso file.
The best way to avoid email infection is to not follow stupid emailed instructions.
Re: Linux security
23-08-2012 2:18 PM
Not sure if clam can filter outgoing messages., I use Google for my email and it scans all messages.
transmission can use blocklists I use http://list.iblocklist.com/?list=bt_level1&fileformat=p2p&archiveformat=gz to download it. Using transgui I control it from a different pc, Or from web gui, click on the spanner and then Peers and set it up there.
Re: Linux security
24-08-2012 1:39 PM
Re: Linux security
24-08-2012 2:11 PM
Re: Linux security
24-08-2012 8:14 PM
Re: Linux security
25-08-2012 10:07 AM
The result is that the manuals are usually written by someone else, or fleshed out by someone else.
