Linux is NOT WIndows - external site
- Linux is NOT WIndows - external site
Re: Linux is NOT WIndows - external site
27-07-2010 4:21 PM
It's just it's such a complete change from the way people are used to doing things it can take a while to get used to. Once you approach it from the right mindset though it's amazing.
This could easily apply to several situations.......
1. Fixed wing pilot moving over tot rotary wing (helo`s)
2. Steam engine driver. moving over to diesel or electric trains
3, pedal cyclist changing to motor bike
4. small child changing from crawling to walking unaided.....
all of the above do not come naturally, ..... they ALL need some sort of assistance, either re-training or personal "one on one" assistance, to get round the problems.... therefore the following is a bit "trite" to say the least...
How does a basic compuer literate person find out the "right mindset" to approach it from in the first place?
Just saying to a Fixed Wing pilot....." you can fly.... fly that helicopter " will not give him/her the "right mindset" ...... even if it is "amazing" ! !
27-07-2010 6:11 PM
I use both, so am not biased but prefer the repository way, then when an app is up-dated/graded I get it automatically, I don't have to go looking for an update to it. But also if you choose the "wrong" repository (like the bleeding edge one) then your system can be a bit temperamental (a bit like windows ;D)
These days the need to compile an application is either because :-
a. it is the latest and contains a fix for a bug you are experiencing
b. not available on your architecture (e..g 32bit only, so need to compile for 64 bit, try that on M$)
c. only available as source code (maybe in the repository if you check though (been there done that, checlinstall is a good example)
But what I think Bob is getting at is go to synaptic FIRST not goggle.
27-07-2010 9:51 PM
Quote But what I think Bob is getting at is go to synaptic FIRST not goggle.
The issue I have with synaptic for an in-experienced user is that for instance if I search there for Java there comes up with numerous file names with containing the word and a very brief description of the file which doesn't really give any clues.
27-07-2010 10:27 PM
28-07-2010 1:56 AM
It's gotten too clunky.
28-07-2010 9:27 AM
Quote from: AverageWhiteBloke The issue I have with synaptic for an in-experienced user is that for instance if I search there for Java there comes up with numerous file names with containing the word and a very brief description of the file which doesn't really give any clues.
Well I think that is what the Software Center is aimed at now. On Mint we have had it for the past year or so but it is now coming to Ubuntu.
Here is my one looking for java
28-07-2010 3:08 PM
28-07-2010 5:51 PM
28-07-2010 6:31 PM
The Ubuntu one has 9 entries for java in the internet category.
I rest my case.
28-07-2010 6:48 PM
Also it has REVIEWS which appears to be missing from the U one.
But in both cases the one he waned is right at the TOP of the list.
02-08-2010 7:15 PM
02-08-2010 11:29 PM
I'm even thinking of putting a post up with all the school boy errors I made when switching over while they're still fresh in my mind, before I start speaking gobbledygook like all the other Linux users May be of some use to the newer users.
My first tip being to open your mind and try to forget all you learned with MS products. It is a hassle/interesting depending how frustrated you are but once you get a basic grasp of what's what you definitely see the advantages of using the operating system.
My old laptop has found a new lease of life and so far with the help of the people in here and wine(The app not the beverage) I haven't had to go near codes which is mine and everybody else's pet hate it would appear. In fact staying away from it until you've had a good look round what else is on offer is probably the best way of not falling out with this software early on.
27-08-2010 4:24 AM
The rest of my family insist on using Windows and this brings me to my only complaint the boot manager (grub 2) is the worst Linux software. For the benefit of the rest of the family I have to keep resetting it to point to Windows and there are very few commands that can be easily edited.
27-08-2010 9:32 AM
Not sure if it is in the repo's yet but a search for ubuntu burg should find it. Also look at startup-manager to edit the default selection.
27-08-2010 2:59 PM
Presumably this hasn't been lost in version 2?
