Linux Mint 8 - Helena Released
- Linux Mint 8 - Helena Released
- « Previous
- 1
- 2
- Next »
Re: Linux Mint 8 - Helena Released
26-03-2010 7:01 PM
I knew I'd be back!
I have installed Linux Mint 8 Helena alongside my Vista OS and generally it is very good. However!
I have an NVIDIA GeForce 8600 GT 1gb Graphics card and my LG moniter has a resolution of 1280 x 1024, but I when I go into settings to change the resolution I'm only offered 1024x780 maximum. I have tried to install Nvidia drivers and such but I cannot get the resolution I need.
Can anybody help please!?
I am very ignorant of command line stuff (but willing to take instruction) and I don't know where to find things, so if you are kind enough to reply to me, I'd need instructions with click on X select Y and click on Z... etc...
real basic school boy stuff.
I look forward to any help. Thank you
Matt
26-03-2010 9:22 PM
I have a NVIDIA GeForce 7300 GS 512MB and it's good for 1680 x 1050
I would expect your card to do much better.
How does it compare with the resolution in Windows?
Otherwise, you could consider, with help from someone more experienced in these matters altering your /etc/X11/xorg.conf file.
It is quite likely that this file doesn't exist
This is because Mint is derived from Ubuntu - which no longer uses this file.
Try entering (in a terminal screen)
cat /etc/X11/xorg.confanyway - but do not change this file without outside help!
27-03-2010 8:23 AM
28-03-2010 10:29 PM
I have used both the Nvidia control panel and the screen resolution panel in Mint but neither offer the resolution I can use in windows Vista (1280x1024).
I have changed it to 1152x864 which is improved, but is a bit too thin (it makes the image slightly skinny).
I'm on holiday for a week, so will check here again when I get back.
Thanks again people
Matt
29-03-2010 12:39 AM
1152x864 will give you a 4:3 aspect ratio.
Either of these are for a "old-style" screen - if you have wide-screen you should be using a 16:9 (or similar) aspect ratio.
25-05-2010 11:22 PM
Hello
I originally posted on this thread - http://forums.linuxmint.com/viewtopic.php?f=59&t=19908&start=20 on the Mint forums (page 2)
because I had a problem with my resolution.
I followed some advice and managed to get an acceptable resolution - 1152x864 (though not the 1280x1024 I really needed)
but since then I can't get ANY sound on any part of Mint 8. I know my hardware is ok as I dual boot with Vista and everything works on there perfectly. The sound was absolutely fine on Mint 8 before I did the resolution setting.
Someone kindly posted a way for me to find my sound settings, which are -
~ $ lspci | grep Audio
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
~ $ inxi -A
Audio: Card ATI SBx00 Azalia (Intel HDA) driver HDA Intel
Sound: Advanced Linux Sound Architecture Version 1.0.20
I'm pretty new to this, and not very good with command line stuff. Can anybody help me to get my sound working again please!?
My system details are below from my original post on the Mint Forums -
Original post Details -
Re: How to get Nvidia Cards Reolution set
Postby professormoog on Sat May 08, 2010 12:19 am
Hello! I have recently installed Linux mint 8 (dual booted with Vista) and generally it's good.
I still use Vista most while I'm getting used to Mint. I prefer Mint to Ubuntu, PC Linux, and Mandriva as mostly everything works out of the box with mint, there was too much to do with the other distros to get stuff to work.
My system is - Acer Aspire T671. Dual core 2.8ghz processors x 2; 2GB Ram; 250GB hd; 1GB Nvidia GeForce 8600 GT Graphics card.
I'm having problems with setting the resolution. I have downloaded the drivers reccommended by Mint - NVIDIA-Linux-x86-185.36.15.pkg1.run
I seem to be running the 185.18.36-0ubuntu9 version according to EnvyNG.
I am currently using, 1280x1024 resolution while in Vista but when I'm using Mint 8, I open NVIDIA X Server Settings I don't have that resolution as an option. the nearest I can get is - 1152x864 which makes everything a little thinner, although it is a better resolution than the 1024x768 it keeps re-setting to.
Also when I click on Save to X configuration file I get this - Failed to parse existing X config file '/etc/X11/xorg.cong'!
My question is! - How do I get the resolution I need (1280x1024) and then how do I get it to stay please?
I have tried almost everything I've read to make it work but it doesn't seem to. I am a total beginner. I can't seem to get anything to work in the command line either! So GUI type stuff only please!
Thank you in advance
26-05-2010 9:46 AM
Or try a different distro like PCLinuxOS - not used it myself but some people here like it.
The main issue with Linux at the moment (as it has been for years) is lack of drivers for new hardware, until vendors start releasing drivers for Linux along with M$ & Mac then we will always have this problem.
26-05-2010 11:49 PM
Do you know how I can upgrade to Linux Mint 9 when the stable version has arrived?
I run Vista as my main OS and I'm practising on Mint 8 (which is first in the boot Q), do you know how I'd delete Mint 8 and overwrite it with 9?
Sorry if I'm not making sense!!
Thank you
Matt
27-05-2010 8:38 AM
Do you have anything in you home folder you want to keep? if so back it up. then just boot from the cd and choose to overwrite the Mint 8 partition and off it will go.
27-05-2010 12:26 PM
27-05-2010 1:49 PM
28-05-2010 11:03 PM
I'll give it a go soon and post my success on here as inspiration to others like me
- « Previous
- 1
- 2
- Next »
