Linux Mint 17.2 Released
- Linux Mint 17.2 Released
01-07-2015 10:01 AM
I've switched to Cinnamon from Mate for this release. Somethings are still needing fixed, like wine apps associations not being incorporated into the system, but there are workarounds.
Not sure if I will stay with it though, I found Mate very easy to use, Cinnamon takes a bit of tweaking, or maybe just exploring.
One good thing, I now have the embedded terminal back
Re: Linux Mint 17.2 Released
01-07-2015 2:52 PM
01-07-2015 4:41 PM
I tried Cinnamon in a new partition and quite liked it, when I tried an in-situ upgrade (wipe / keep /home), I found I couldn't install wine, even though it worked fine in the other one, so renamed my home folder then installed again, moving over things as I need them.
01-07-2015 6:15 PM
Haven't updated to 17.2 yet.
01-07-2015 6:22 PM
Been running Mate for past couple of years, but then I used to use Gnome 2.
01-07-2015 9:01 PM
Virtually no Ubuntu contamination.
02-07-2015 9:11 AM
02-07-2015 10:29 AM
I've never had any problems (but I've never tried VNC).
02-07-2015 11:18 AM
I wanted to love it with rolling updates etc, but after about 3 months I gave up.
02-07-2015 12:31 PM
From earlier posts it appears users will get the opportunity to upgrade to 17.2 through the update manager but there are some links to posts that provide instructions on how to update to 17.2
Must admit I am a bit puzzled about that, why would you do that if it can be done through the update manager instead of the terminal ?
02-07-2015 3:38 PM
It will appear as an OPTION in the upgrade manager later. You don't have to upgrade to 17.2 from 17/.1.
02-07-2015 4:28 PM
02-07-2015 4:51 PM
finshed installing Mint 17.2 on your hard drive ?
02-07-2015 5:15 PM
However XP/W7 wouldn't see the network (ethernet) or the wifi without download (elsewhere) a driver, so ....
However the UPDATE will not remove anything, only update them to the latest versions.
02-07-2015 7:19 PM
I took the easy way out and bought a wifi dongle for a few pounds which works with windows and linux.
