Linux Live USB stick formatting query
FIXED- Subscribe to RSS Feed
- Re: Linux Live USB stick formatting query
29-06-2016 2:46 PM
I want to put a version of Linux Mint on a usb stick, but it needs to be formatted first... what system do I use.... the usb will be used on both 32 and 64 bit machines...
NTFS
FAT32]
ex-FAT
and suggestions which version of linux mint 32 bit or 64 bit I should select on the UNETBOOT site
thanks
Fixed! Go to the fix.
29-06-2016 2:51 PM
As I understand it it should be FAT32 and if your PC supports it go for x64.
29-06-2016 3:03 PM
thanks mook,,... will mint 17xx 64bit run on a 32 bit laptop from the usb stick? possible install if necessary cos windows has failed,.
29-06-2016 3:07 PM
Sorry @shutter the answer is No as it's name implies you'd need a 64 bit machine to do that.
29-06-2016 3:19 PM
ok thanks will get the 32 bit, cos I know that runs on a 64bit machine ok.. cheers
29-06-2016 3:29 PM
@shutter - If you've got a 64 bit machine then get the x64 install. Why would want to use 32bit if the architecture is 64?
29-06-2016 3:45 PM
The Live usb stick will be used on BOTH as per my original post... so I am thinking that a 64 bit version on the stick will not run/install on a 32 bit machine ? ? ?
29-06-2016 3:48 PM
You did say this and I completely missed it! My excuse is it's one of those days.
29-06-2016 3:53 PM
have a nice day.......
29-06-2016 9:07 PM
It would be a very old machine that is not capable of running 64-bit software, even if it ran a 32-bit version of Windows.
30-06-2016 11:07 AM - edited 30-06-2016 11:08 AM
