Linux Live USB stick formatting query
shutter
Fixes: 65
I want to put a version of Linux Mint on a usb stick, but it needs to be formatted first... what system do I use.... the usb will be used on both 32 and 64 bit machines...
NTFS
FAT32]
ex-FAT
and suggestions which version of linux mint 32 bit or 64 bit I should select on the UNETBOOT site
thanks
10 REPLIES 10
Re: Linux Live USB stick formatting query
As I understand it it should be FAT32 and if your PC supports it go for x64.
shutter
Fixes: 65
thanks mook,,... will mint 17xx 64bit run on a 32 bit laptop from the usb stick?  possible install if necessary cos windows has failed,.
Sorry @shutter the answer is No as it's name implies you'd need a 64 bit machine to do that.
shutter
Fixes: 65
ok thanks will get the 32 bit, cos I know that runs on a 64bit machine ok.. cheers
@shutter - If you've got a 64 bit machine then get the x64 install. Why would want to use 32bit if the architecture is 64?
shutter
Fixes: 65
The Live usb stick will be used on BOTH as per my original post...  so I am thinking that a 64 bit version on the stick will not run/install on a 32 bit machine  ? ? ?
You did say this and I completely missed it! My excuse is it's one of those days.
shutter
Fixes: 65
Roll_eyes
have a nice day.......Wink
ReedRichards
Seasoned Pro
Fixes: 25
It would be a very old machine that is not capable of running 64-bit software, even if it ran a 32-bit version of Windows.
HairyMcbiker
All Star
Fixes: 21
@shutter have a look at Multicd
It lets you put both 64&32 bit versions on the same usb stick
As to format FAT32 ONLY.
