Linux Live USB Issues
- Linux Live USB Issues
04-05-2018 7:16 PM
I have been trying a number of linux distros Mint and PC Linux on my laptop, but for some reason i cannot get the wifi to work. Is this normal?
Re: Linux Live USB Issues
04-05-2018 7:53 PM - edited 04-05-2018 7:54 PM
@morgan2476 Depending on the age of the laptop..... and if you are using a "broadcom" based wifi card...
a quick look on google brought up this page..
https://www.ghacks.net/2015/03/27/how-to-get-wifi-working-in-linux-mint-after-installation/
which may or may not help...
this is what I searched for... how to solve no wifi network on linux mint
Which resulted in many pages of info... ( obviously, you will have to connect via a ethernet cable to get on the net to start with ! ! )_ ..
Good luck
04-05-2018 8:07 PM
It's possible on a very new model of laptop with an unsupported wifi card...
An ethernet cable connection is much more likely to work.
What does the command iwconfig show?
Try following the instructions in https://kmuto.jp/debian/hcl/ which tries to detect your hardware and any installed drivers.
05-05-2018 12:04 PM
