Linux Kernel High jacked
- Linux Kernel High jacked
17-08-2016 7:04 PM
Is this something most need to be bothered about ?
https://blog.lookout.com/blog/2016/08/15/linux-vulnerability-android/
Would most users not get a message advising an update was available thus avoiding this problem ?
We are born into history and history is born into us.
1 REPLY 1
Re: Linux Kernel High jacked
17-08-2016 7:18 PM
If you are bothered use the patch to make it a non issue.
