Linux Help
Fixes: 118
Linux Help
Tried to start a virtual copy of Win7 in VirtualBox but got the following message.
Any suggestions on how to fix.
3 REPLIES 3
Fixes: 387
Re: Linux Help
Yes - ask on either the VB support, or a Linux board.
Fixes: 1,495
Re: Linux Help
sounds like you need to reinstall VirtualBox.
Fixes: 585
Re: Linux Help
@bmc
has your linux system updated ?
linux normally rebuilds additional kernel drivers e.g vboxdrv automatically after a kernel update using the dkms system.
However, if you have secure boot enabled , they will also need to be re-signed which is a manual operation.
