Linux Dual Boot DVD-R/CD-R Problem
- Linux Dual Boot DVD-R/CD-R Problem
- « Previous
- Next »
Re: Linux Dual Boot DVD-R/CD-R Problem
29-10-2019 7:11 PM
Spherical objects to it! I've got nowhere fast.
I go back to an earlier question:
"On a general note, is it worth trying to install Ubuntu within Windows using wubi? What pitfalls are there?" (where 'Ubuntu' can be said to stand for any supported flavour).
Thoughts?
30-10-2019 6:47 PM - edited 30-10-2019 6:48 PM
@thejudge the last time I tried to install Ubuntu within Windows using wubi it did work ok but was quite a bit slower compared to installing it natively.
However that was about 15 years ago......
Have you tried the mini.iso from ubuntu? Only 73MB... It does a network install. Even if your cdrom/dvd drive is a bit old and kanckered. It should hopefully just be able to cope with the first 73Mb on the inner part of the disc.
http://archive.ubuntu.com/ubuntu/dists/bionic-updates/main/installer-amd64/current/images/netboot/
Or flash the 73MB mini.iso to a USB-Stick using Rufus.
https://en.wikipedia.org/wiki/Rufus_(software)
31-10-2019 4:56 PM
Have you tried other applications to burn your ISO to USB/CD/DVD?
These should work on all platforms (32 & 64bit)
There are bound to be other choices...
- « Previous
- Next »
