Linux Boot Disc
- Linux Boot Disc
Linux Boot Disc
11-09-2015 8:16 AM
I have an old copy of Linux Mint (version 9) on a boot DVD that I occasionally use when a (Windows) computer will not start and I want to look at the hard drive and possibly copy files to a USB drive. I'm wondering if I should update that to cope with newer hardware. Is Mint still the best choice for this specific application?
8 REPLIES 8
Re: Linux Boot Disc
11-09-2015 8:45 AM
I have Mint 14 on a bootable usb stick, for similar operations... works well.... especially if you can get the wireless setting on the usb stick as well,... then if there are problems with the wifi, then it should still connect on the usb stick.
Re: Linux Boot Disc
11-09-2015 9:20 AM
I normally use UBCD rather than a specific live CD - provides just about everything you need!!
Phil
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Re: Linux Boot Disc
11-09-2015 9:39 AM
Having just needed to sort out a duff hard drive on a Sony laptop I found this did the trick http://www.howtogeek.com/howto/windows-vista/use-ubuntu-live-cd-to-backup-files-from-your-dead-windo... and seemed to do everything I needed
Re: Linux Boot Disc
11-09-2015 10:08 AM
I've also successfully used an Ubuntu Live CD in similar situations.
Re: Linux Boot Disc
11-09-2015 11:07 AM
Unless the hardware is newer than the distro then you don't really need to update the disk.
As long as you can get on-line you can usually get a driver, however Mint 9 is a bit out of date, you would be better updating the disk to Mint 17.2.
Re: Linux Boot Disc
11-09-2015 1:23 PM
Why are you still using Windows if you have to rescue it with Linux?
Re: Linux Boot Disc
11-09-2015 1:31 PM
Why do you have to continue trolling - the reason for the question was very clear
Re: Linux Boot Disc
11-09-2015 1:34 PM
Quote from: vilefoxdemonofdoom Why are you still using Windows if you have to rescue it with Linux?
This troll has been reported to moderators...... not that they will do anything.... but it would be a good idea if he desisted from trolling anyway...
