Linksys ???
haletony
Linksys ???
Connecting to the internet via a Linksys compact wireless G USB adaptor. Each time I have click on Plusnet on the Linksys site survey and then on Plusnet wireless on the Linksys profile. any idea's
Fixes: 62
Re: Linksys ???
Which operating system are you using.
If  a version of Windows are you using Linksys software or the built in windows system
haletony
Re: Linksys ???
Thanks for your reply, I'm using Windows XP service pack2 and Linksys software
Fixes: 62
Re: Linksys ???
I assume you have tried these steps http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4090 including the Save Profile at the end
Just saw this in the Cisco Forums - worrying isn't it - http://homecommunity.cisco.com/t5/Wireless-Adapters/How-to-save-profile-for-a-wireless-network/m-p/2...
Fixes: 62
Re: Linksys ???
I am moving this to the Windows Forum as it isn't strictly a router problem
Fixes: 25
Re: Linksys ???
I recommend you ditch the Linksys software (which is manifestly amnesiac) and let Windows control your wireless settings.
haletony
Re: Linksys ???
Thank you I'll give it a go
