Line speed
Fixes: 9
Line speed
If you are on the cheapest Plusnet package and you check your download speed is that the same as the Line speed.
What I am really asking is do more expensive Plusnet packages provide an increase in speed or is the speed on the cheapest packages going to be the same as the most expensive one ?
I Have checked out the info about the different packages but a number of columns refer to line speed so can someone clarify this for me.
pierre_pierre
Re: Line speed
the synch, profile and download dont care what package you are on, the only thing that is changed is the limits on speed for the various packages see here for that http://www.kitz.co.uk/isp/plusnet_shaping.htm
James
Re:Line speed
Hi Gleneagles,
A lot of the differences between packages relate to both the usage allowance and how different types of traffic are handled.  However, Premium and Pro customers are also entitled to an upgrade to ADSL2+ when it is available at their exchange.
Luzern
All Star
Re:Line speed
Quote from: Jameseh
I'm antediluvian and still on legacy Home Surf. Out of general interest how will such and similar products be considered? HS seems to have quite a bit in common witht e higheer grade current packages.
Fixes: 166
Re:Line speed
We're still pulling the full plan together on the legacy accounts and which of these will be moved to ADSL2+ and when.
 Chris Parr
 Plusnet Staff
