Line Out - Line in Volume reduction
- Line Out - Line in Volume reduction
15-01-2013 4:47 PM
Normally this is done by a double ended jack lead, from the REC or Line Out, on the back of the receiver, to the MIC on the laptop. However, this portable receiver does not have a Line Out or REC socket, only the earphone socket. and the level is very high and likely to damage the soundcard.
So.... I need to be able to reduce the output level from the earphone socket to a similar/comparable "Line out" level.
Calling on all you techy`s to suggest how I can do this for next to no money...and of course, very simple..... I was thinking of a resistor in the line, but don`t know what value it would need to be....
It would be nice if I could also use the speaker to listen to the signals, at the same time, but plugging in a jack plug cuts out the speaker, as for using with phones. I suppose I could wire up an external speaker and use that, with a jack lead into a double socket to single plug adapter.
If you need to send me a circuit diagram, with parts list. pleas PM me for my email address....
Thanks guys.
Re: Line Out - Line in Volume reduction
15-01-2013 5:04 PM
15-01-2013 5:35 PM
Thanks MisterW
Update....
Have seen one on ebay (Exactly the same pic) for £3.25 inc post.... so ordered it....
Many thanks
15-01-2013 5:46 PM
15-01-2013 7:14 PM
To control the input level to the LINE IN just adjust the volume control on the receiver.
15-01-2013 7:34 PM
Thanks for the input...
15-01-2013 7:50 PM
15-01-2013 8:52 PM
loss of hearing caused by listening to radio "mush" in between signals for 10 years ! ! ..
